window rolls down when you turn off car - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2011, 10:56 PM
put up or shut up
boss wants me to mess with it for the first part of the morning. Says it works normally but rolls down when you shut off the car. Think this is a short? I'm not sure what that could be..
Old 10-29-2011, 04:42 AM
EOD Guy's Avatar
What type of car is it? Does it have an after market alarm on it?
Old 10-29-2011, 05:22 AM
deadbodyman's Avatar
Wiki Edits: 11
LOL ,reverse the wires so it goes up when you turn it off....thats a wierd one.
Tell the boss the other guys are getting mad because you always get the good stuff and give it to one of them just to keep the peace...
Old 10-29-2011, 06:23 AM
gmc1990rodder's Avatar
Sounds like it may need a priest instead of a mechanic.... JK i would check the control switch first..not sure what type of car/truck it is but it does sound like a short of secondary source of power from somewhere else
Old 10-29-2011, 07:14 AM
LATECH's Avatar
Need to know make - model- year.
Chances are you will need a GOOD scanner .
Many newer cars have door modules that control window and drivers seat , mirror , memory function. Could be a switch problem or a wiring problem or a memory circuit malfunction in the door module etc. Earlier cars used an "express" module that rolls the window down by touching the window switch to the down posistion, then rolling the window completly down.Between the retained accesory power function operating normally and a defective switch or express module , this could be the cause. Does it have RAP ( retained accesory power) ? If so try opening the door before shutting off the car to see if the problem ceases. That would help to indicate wich direction to look.
Old 10-29-2011, 09:08 AM
put up or shut up
I'd say it's an early 2000 lexus 300
Old 10-29-2011, 09:10 AM
put up or shut up
The good stuff? hahahaha. Yeah right.
Old 10-29-2011, 09:12 AM
put up or shut up
That's a good question. I can't recall. I'd say not cause it would seem it haves a factory one.
Old 10-29-2011, 09:19 AM
put up or shut up
not sure if it has RAP. I didn't notice any Tupac Cd's in the car, kidding.
so if it happens with the door open what would that indicate? Btw, thanks for the response, you really sound like you know what you're talking about. Much beyond my comprehension in electronics.
Old 10-29-2011, 09:29 AM
T-bucket23's Avatar
Wiki Edits: 26
Check for blown fuses. Could be when you turn the car off something is back feeding through the window control circuit and activating the window. I have seen some strange issues. Had a Cadillac that the interior lights would come on at different times due to a blown fuse for something else.
Chet
Old 10-29-2011, 09:33 AM
T-bucket23's Avatar
Wiki Edits: 26
Had another thought, on most cars when you shut the key off it unlocks the doors. It is possible that they are run but the same module or share common wiring in the door. You may want to look for shorted or broken wires in the boot between the door and the body or in the door. Could also be the switch module is internally shorted
Chet
Old 10-29-2011, 04:03 PM
EOD Guy's Avatar
Some of the after market alarms have that feature, hold the lock button for more than 4 sec and the windows roll down. Some factory systms do the same thing..... intent was to allow the heat to escape while you were walking across the parking lot etc...... I'd look up the features avail on a Lexus for that year etc.... and I'd search up under the dash area for a brain box ....
Old 10-29-2011, 04:07 PM
LATECH's Avatar
If it happens with the door open, then it isnt related to Retained accesory power. It is quite possible that the drivers door window express module is faulty. I would check for a couple bare wires in the umbilical from the door to the A pillar Jamb. ( the flex for the wiring from the door to the car)
You will have to pull the kick panel to get the harness unfastened, to get some slack in the wiring and to pull the convoluted flex from around the wiring( the accordian looking thing that protects the wiring between the door and body )
Sounds more like a wiring problem than a defective module, but a module could be in play here.
Old 10-29-2011, 04:43 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Bad switch
Probably the remote up and down switch bad, or you can try changing out the FOB battery i have seen others do what you have described and the battery needed changing. JMO
Cole
Old 10-29-2011, 05:03 PM
LATECH's Avatar
Reprogramming door module
We used to have similar problems with sunroofs on lexus' and such.Some times it was a simple reprogramming that fixed it.
It could be that the door module needs to be reprogrammed.I just dont recall if a 2000 lexus needs that for the window, but I do remember that is a common problem with the sunroofs,
Before you tear into it, try running the window down and holding the switch in the down posistion 5 seconds after the window bottoms out, then raise the window and continue holding the switch up for 5 seconds after the window is at the top. IIRC this is what we used to do.and it usually fixed the trouble.
Nissans are similar but to do them the door panel has to come off, but they do display similar issues when they malfunction
It has been 3 years since I worked at the auto auction, so sometimes I dont recall this stuff as easily as it was yesterday.LOL
S-10 to Rolls Royce graft wakemaker Suspension - Brakes - Steering 12 12-16-2010 10:59 AM
4l80e rolls sprags hrodgmc Transmission - Rearend 7 10-11-2006 05:49 PM
Mike Rolls Fitter Mike Introduce Yourself 3 01-14-2006 03:23 PM
GM window switch turn on 5window Electrical 1 05-15-2005 07:50 PM
Rolls Royce racecargurl Hotrodders' Lounge 9 01-15-2003 10:13 AM
