window run felt channel - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2013, 07:17 PM
How do you guys fasten the felt to the channels? I have a glass car with wooden channels. Glue or small screws? Screws would hit or rub on the glass?
Old 01-10-2013, 08:19 PM
sedanbob's Avatar
I used u-shaped rubber channels in the top and sides, glued into my fiberglass car. I used screws for the fuzzies. I used small flathead screws, and countersunk the holes in the fiberglass frame. When I tightened the screws, they dimpled the metal strip, so they were below the raised fuzz. I think the same treatment would work for your felt to keep it from touching the window glass.
Old 01-11-2013, 12:42 AM
327NUT's Avatar
My POS '32 Victoria that was thrown together by "Downs Mfg." had the entire window felt/metal channel bondo'd in to the door. If you ever had to change it you would have to grind it out.
Old 01-11-2013, 10:03 AM
1971BB427's Avatar
Mine is a metal car, but since I couldn't purchase the factory parts for my channel I had to locate some for other old USA made cars, and adapt them. I glued my felts in with 3M weatherstrip adhesive two years ago, and they're holding up great.
Old 01-11-2013, 10:11 PM
Northstar T's Avatar
Gone sailing
I've used adhesive backed fuzzy velcro. readily available in a variety of widths and the stick-um is very strong. any fabric shop will have rolls of the stuff.
N*T
Attaching window run channel menace 65 Body - Exterior 3 06-16-2012 08:15 AM
Window channel felt? Madmax305 Body - Exterior 1 02-16-2010 07:00 PM
Where to find window run channel, etc.? TnTrader Body - Exterior 9 11-06-2009 10:52 AM
1952 Chevy Window channel and felt installation eneas kid Interior 4 01-05-2008 01:40 AM
window felt 46_stvblt Interior 17 12-30-2005 09:34 AM
