window tints - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2003, 03:35 AM
New Member
Post window tints
I,ve recently bought a 56 f100 from CA and its just arrived back here in the UK. Unfortunatly it,s been down to the window tinting shop and had a severe attack of tinting which I hate. Anybody know how to remove the tint (it looks like a film), without causing any damage. It seems to be well stuck I can,t move it and do not want to try a blade of any sort. I have contacted a widow shop here and they suggested hot soapy warter and peal it off, or solvent depending upon what film has been used. Anybody else know better as solvent near good paint sounds a bit traumatic to me.
Old 05-29-2003, 12:33 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Post
Baily, I'm no expert on this, but I've taken off a tint job once before. Let me tell you that it sure was a pain in the a**, at least the way I did it. I started by peeling off a corner at the top with a razor blade, and from there I took a heat gun and slowly peeled it off. I don't know if this is the "correct" way to do it but it worked, and I didn't use any solvent except for a little carb cleaner sprayed onto a rag to get the little stickey parts off. Good luck.
Old 05-29-2003, 05:00 PM
Jag Daddy's Avatar
British Style with USA Muscle
Post
You may want to consider putting a clear or very light tint back on, why? because I don't know if 1956 trucks have decent safety glass. It will keep the glass shards out of your eyes in case of an crash
Regards
Mark
Old 06-02-2003, 07:20 PM
black66's Avatar
www.airriderz.com
Post
They make a spray that will loosed the tints clue. All you have to do is spray the tint with the liquid tint remover. Let sit for a minute and the tint will scrape right off.....No harsh chemicals and works great..... You can buy the tint removing spray at Kragens for less than $10.00 bucks.....
Old 07-16-2003, 08:26 PM
My friend had his window out of the car when we were restoring it and we soaked it with gasoline and lit it on fire that stuff melted like sandwich rap into a little ball. After it cooled we pulled it off and that was that.
Old 07-16-2003, 08:32 PM
DLRodder, you are joking, right?
Old 07-17-2003, 08:10 PM
No it was a 65 bug rear window. It didn't have any defroster lines if that makes any difference.
