Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Window track discussion
Old 12-26-2005, 04:08 PM
MARTINSR MARTINSR is online now
Originally Posted by crashtech
If it was my car, I might wire wheel the worst, zinc prime the spots not involved with mechanical motion, check all the plastic and/or pot metal parts (if any) for wear and breakage, grease the sliding/moving areas real good and put it back in service.
Crash, I am with you. Unless I was building an out and out 100 pointer I would simply apply some WD40 and white grease and put it back together.
Those parts had a very thin zinc plating, there was rust on them thirty years ago, the windows have been working just fine all that time. Lube them up and get back out on the road with a smile on your face and the tunes cranked up.
