Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Window track discussion
Old 12-26-2005, 08:44 PM
baddbob baddbob is offline
I agree, clean them up, prime them with some epoxy and grease them up good with white lithium grease. They'll hold up just fine. Be sure to inspect all the plastic rollers, these have a tendancy to crack and shink with age and also wear out. Is that outer wheelhouse welded in solid or just an illusion in the photo? Clean up your rocker and inner quarter and whellhouse well and prime before you install the new quarter. It's much easier to get these areas prepped and primed with the quarter off. After the quarter is on go back in and spray your seams with 3M Rustfighter or something similar. Bob
