Windows and door locks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2009, 04:32 PM
Jethrotrc's Avatar
1badchev
Hi everyone looking for a little help...i just replaced the door panels in my truck (87 Chevy) Now my driver side window rolls up and down like normal, the passenger side only works sometimes from the driver door and Never from the passenger door, ive replace the switch on the passenger side and still nothing. any help guys (or gals) ???? Thanks
Old 10-27-2009, 10:16 AM
Eric63M's Avatar
Last journal entry: Getting all the parts together for my LTX build
Start by checking to wires, make sure they are secure in their conectors and look for damaged wires.
Or you can use a multimeter on the switch (look at a schematic of it) and see if the switch is bad, if so replace the switch but it sounds like a loose wire to me.
Good luck,
Eric
Old 10-27-2009, 12:47 PM
Jethrotrc's Avatar
1badchev
I bought a new switch and it did nothing. Ive put a test light on the harness and it has power where it is supost to
Old 10-27-2009, 01:37 PM
Eric63M's Avatar
Probably a loose ground somewhere in the system then. Might have a broken wire somewhere, not sure if it will be grounded on the door or through the harness.
Good luck,
Eric
Old 10-31-2009, 03:21 PM
fast68's Avatar
likes chevy trucks & boobies
going to be bad wire or bad switch
one or the other
since we know the motor works
try more switches etc
maybe its a bad wire plug on one or the other or the pass side door
check terminals in the plug
one may be burnt or bad
