Windshield Frame doesn't fit - help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2003, 11:20 PM
Post Windshield Frame doesn't fit - help
Hi , I'm new to this board so I'm hoping someone will have a solution to my problem. I chopped the top on my '30 A sportcoupe and thought everything checked out. Unfortunately I didn't check the windshield frame to ensure it sat flat before I painted the car . Now with rubber seals installed (Stock type) , I have about a 3/16 inch gap at the top of the piller that tapers to nothing at the bottom of the frame. Placing a straight edge on the face of the pillar shows a bulge just above the cut area. My guess is after welding and skim coating the pillar with metal to metal I created a bulge. Other than stripping down the Bc/CC is their another option to sealing the frame? Thanks , Dale
Old 01-02-2003, 11:53 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
My reader comprehension is about a 3 from 1-10 so forgive me if I get your question all wrong. Is your problem that you have a bulge at the top of the frame the prevents the winsheild from sitting flat with the rubber? If so this may not be totally your fault. That metal 2 metal filler is weird stuff. I used to use it, I did a '69 charger about 2yrs ago and used metal 2 metal and on 3 or 4 of the spots even though it was smooth and true right before paint about two weeks later it started to bubble and bulge. Try sticking it with a pin in a few places and put some pressure on it. If that doesn't lower the bulge, take it down and fix it.
To answer if theres and option other than the rubber seal, yes. Go to your local auto store and buy a box of 3M windsheild urethane sealent. Its a coiled up strip of black urethane sealent it will solve your sealing problem enen with the bulge. Never tried it on a verticle windsheild, but considering its pretty sticky stuff it could work with some clips to hold the windsheild in place, or maby chrome strips. I'm sure someone will have a solution for you if I bomb out.
HK
Old 01-03-2003, 06:15 AM
New Member
Post
Ihave a 31 coupe stock no chop and it is the same way fits perfect at the bottom top has gap
i routed the wood at the top and set it back and i bought all new parts.i was told by many people
that some were like that
Old 01-03-2003, 05:00 PM
Dave E Shank's Avatar
Post
HEY 30: There was a story in Rod& Custom mag about a product for trimming around windows. The website is WWW.flexchrome.com it looks like a great product. I hope it helps. DAVE SHANK
Old 01-05-2003, 03:41 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Post
30...if you get a chance snap a pic and post in on here so we can better know what you are talking about then I'm sure we can help you solve it.
Kevin
