Windshield wiper arm removal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 04:17 PM
Madmax305's Avatar
I hope this is in the right forum? I hate to sound like a noob, but how do you remove the windshield wiper arms on a 1967 El Camino?
Old 08-05-2010, 05:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If you are talking about the complete arm, Well what i do i figure it's the same as my 67 camaro, I lift the arm up and take a large flat head screw driver or something similar and place it under where it sits and slides down on the grooves and apply a little pressure and twist the flat head while lifting, Always works for me anyway. Just be careful not to scratch the paint might want to place a rag down just to be safe, Or someone else might have a better way.JMO
Cole
Old 08-05-2010, 06:00 PM
poncho62's Avatar
Wiki Edits: 5
Is there a pair of little holes in the side of the arm?......If so, put a nail or drill bit through there while holding the arm off the windshield. With the pin in there, it holds the arm up, so you can wiggle it off the spline.......some of them also have a little spring tab under the arm, that you push back while wiggling it.
Old 08-05-2010, 07:44 PM
Madmax305's Avatar
I just checked, there are no holes, this has me baffled!
Old 08-05-2010, 07:57 PM
eloc431962's Avatar
Wiki Edits: 37
Hey Max, I just went out and looked at my 67 camaro which should be the same, Look where the arm slides down on the shaft, if you look you should see a small tab on the underside of the wiper arm. take a small screwdriver and work the tab down and lift the arm off. If you need i will go try to take a pic for you just let me know. This is the tab poncho is talking about.
Cole
Old 08-05-2010, 08:01 PM
Madmax305's Avatar
Cole
Wow, thanks Cole! I just did you what suggested and I got the arm off. Thanks for all the help and replies guys....
Old 08-05-2010, 08:11 PM
eloc431962's Avatar
Wiki Edits: 37
Good deal glad you got it.
Cole
'03 GMC wiper arm removal, out of time. 68NovaSS Body - Exterior 2 01-25-2009 02:33 PM
Wiper transmission - 60 Vette KENMO General Rodding Tech 0 06-23-2008 09:48 AM
'32 Ford Truck Windshield Wiper Systems rcrfly General Rodding Tech 2 08-12-2006 09:50 AM
Windshield Wiper on '31 Roadster Irelands child Body - Exterior 2 03-24-2006 07:21 AM
Mustang II upper A arm removal RodFather Suspension - Brakes - Steering 4 08-30-2004 02:52 PM
