windshield wiper motor or switch or both malfunctioning? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2010, 04:10 PM
i have a 1994 ford taurus and i have been driving it around in the rain and slow without windshield wipers for about a wek or two now. I dont know if its the motor or the switch but both are pricey. I am trying to figure out which one it is but i dont know how. i wanted to hook it up directly to the battery to test it the same way i did my starter and fuel pump but the wiring is too complex.
How do i determine which of the two components is broken?
How do i bypass the switch next to my steering wheel to just turn it on?
What are the seven wires for and why do they turn into 3 prongs inside of the wiper motor?
How do i find the ground and the hot wire thru this jumbled mess?
P.S. Ignore the broken wires I did that and they are not why its not working and they arent touching.. Every last fuse in this car is good.
Old 12-23-2010, 05:20 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Your pics don't work.
Do you have a test light ? Find the hot wire with a test light turn the key on and check the wires till you find the hot wire. JMO Or you can take a jumper wire to see if it will work. Have you checked the fuses / relays ? did they quit all at once ?
Cole
Old 12-23-2010, 06:12 PM
T-bucket23's Avatar
Wiki Edits: 26
Cole
Check to be sure the motor is grounded. If that is the one that the motor mounts to a big aluminum frame I have seen several that the the frame ground wire becomes so corroded it wont pass current anymore. You can try running a jumper wire from the battery neg to the motor frame and see if the motor runs.
If it is the one I am thinking of, the ground wire for that frame unit is one the passengers side.
There is a module that drives the motor. Here are the pinouts. There appears to be a couple switches in the motor that feed back to the module to tell it if the motor is parked or not.
Pin 1 hot all the time dark Green
Pin2 position sensor to module Black/pink
Ping 3 position sensor Red
Pin 4 Ground Black
Pin 5 Motor Control Yellow
Pin 6 Motor Control Dk blue/orange
Pin 7 Motor control White
If you unplug the connector and run a wire from the battery + to pin 5 of the motor and a wire from teh negative to pin 7 the motor should run in high speed, pin 6 to neg will run the motor in low speed. The rest of the pins are to let the module know where the motor is as far as parking
Chet
Old 12-23-2010, 09:16 PM
Pin 4 Ground Black
so you would say then that this is A definitive test to determine if these motors are any good?
Old 12-24-2010, 07:22 AM
i dont have a test light or a clue about the price. i just spent all mymoney on an '84 crown vic then got a bunch of tickets taking the owner home last night. i need to figure out what the issue is quickly, rig something up, and solve the issue. the wiper issue caused me to be suspended frommy job due to a passenger to said job complaining about her safety.. need help BEFORE MONDAY.
Old 12-24-2010, 08:51 AM
eloc431962's Avatar
Wiki Edits: 37
You need to do what Chet has explained to you and see if it will run or not. He has explained how to do this just follow what he has told you.JMO
Cole
Old 12-24-2010, 01:20 PM
T-bucket23's Avatar
Wiki Edits: 26
i dont really understand that question. If the motor runs when connected as stated then it is good and you need to look elsewhere. Check the simple stuff first. As I outlined earlier I have seen several of those and other ford models with bad grounds for the cowl that the wiper motor is bolted to.
Chet
Old 12-27-2010, 02:36 PM
T-bucket23's Avatar
Wiki Edits: 26
Any progress on this
Chet
Old 12-29-2010, 02:31 AM
hmmm. i was able to hook the OLD one directly to the batt. ran great.. i then tried to hook it to the hot wire on my defroster and it ran great for 15 min or so then did not work right. i was finally able to hook it to my fuse panel. at first the light switch that i was using would not carry the juice for some reason but not its working.. odly though i still have speed control via the handle next to the steering wheel so i dont know whats going on but its working for now..
Big Block/Windshield Wiper Motor MWG General Rodding Tech 3 09-25-2008 09:24 AM
Windshield Wiper Motor nikkicamaro Electrical 2 03-05-2006 04:57 PM
Windshield Wiper Motor - '30 Model A StripeUSA General Rodding Tech 2 11-04-2005 05:10 PM
windshield wiper motor 65galaxie500 Electrical 1 10-21-2002 04:58 PM
windshield wiper motor and e.i. for 352ci 65galaxie500 Electrical 1 10-20-2002 12:09 PM
