Windshield Wipers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2006, 12:56 PM
mosstrooper's Avatar
Windshield Wipers
What do builders of older cars do about a wiper system in the US and elsewhere, especially converting from Vac to electric.
Here is the solution in the UK, this system comes from the BMC Mini and other cars from that maker. As you will gather from reading and looking at the diagrams, this is a very versatile unit which can be adapted to any vehicle.
What are your thoughts and solutions?
http://www.s-v-c.co.uk/SVCWIPERS.HTM
Old 07-16-2006, 01:02 AM
dinger's Avatar
There's quite a few kits on the market, same principle as the Lucas. I bought one for my coupe, I think it was about 60 bucks. Dan
Old 07-16-2006, 01:48 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Rain-X
Old 07-16-2006, 09:33 AM
Bad Rat's Avatar
Last journal entry: SACRAMENTO AUTORAMA 02/05
Wiki Edits: 2
Moss.. That diagram is basically the same as the specality kit [made by specality windows] they work good and are fairly easy to install,, but are designed for cars under const,, because it requires welding,, and are not cheap,, about 300. bucks ,,, I second the motion of RAIN-X Bill
Old 07-16-2006, 11:11 AM
I bought the complete Lucas system on ebay (used) for $20. No welding is required with the Lucas. I need to order a new centre tube and longer drive rod, but that won't cost much, the prices are on the page I highlighted.
Old 07-16-2006, 06:49 PM
Wiki Edits: 31
the vac wipers don't work in my '51 Chevy, I will use rainx if I cannot get them working, I think it's a vac leak in the hose so I'm not worried. some cars like mine do have electric conversion kits but unluckey for me, only come in 12v, my car will remain 6v.
Old 07-17-2006, 11:22 PM
PrimeMover's Avatar
Sittin' on top of the world...
Those old GM vac motors get vaccum help from the fuel pump too. Sometimes the pump diaphram needs to be replaced, to have 'em work right. Too bad you're gonna stay with the 6 volt system. I've got a stock 55 chevy 12 volt electric motor on the 53 and I think it'll work on a 51 too, but I'm not sure. On my car, it bolts right up with two screws and even the old stock control cable works with the 55 motor, The wipers cancel perfect too. It's a good way to go, if you can find one. In 55, electric wipers were an option so some of 'em will have the same vac motor as the 53-54 cars.
Old 07-18-2006, 11:52 AM
Wiki Edits: 31
It's staying 6v for now, I don't have the budget right now for 12v, plus I like the look of the generator. where the vac line runs through the firewall there is like 6" of electrical tape wrapping about a 6" section. and the engine runs better if I pull the wiper line off and put a vac gauge on it. the wiper motor looks great. I don't have the fuel pump with the intergrated vac pump, runs off strictly manifold vacume.
windshield wipers that actually work? WayOutCat Hotrodders' Lounge 12 07-15-2006 01:58 PM
windshield wipers going crazy PFC Ellia Electrical 3 11-18-2004 01:04 AM
1969 Camaro windshield wipers JeffShuman Electrical 3 09-30-2004 03:49 PM
Windshield Wipers for 1954 Chevy Pickup? horvath Body - Exterior 8 09-11-2003 09:25 PM
Windshield wipers. Silver_Camaro Electrical 2 06-26-2003 09:32 AM
