windsor defect? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2004, 11:36 PM
goose's Avatar
back to action!
Question windsor defect?
hey people, i have my 351 on the stand stripped down to the bare block and am in the process of cleaning it up. i was showing my friend and he noticed a small hole in the lifter galley. so i examined it more closely and now i wonder if it's even supposed to be there. looking from the front of the block, it's just left of the distributor and about one half of an inch up from the valley floor and the same distance from the lifter bore. it doesn't look like it was cast there, and has a rough un-even oval shape to it about the size of a smartie. i looked in my manuals but can't find any pictures of the valley from that angle. i was wondering if this hole was made after the block was cast? maybe it is perfectly normal except that it is so sloppy. anyone see this before? thanks in advance.
Les
Old 02-03-2004, 07:10 AM
woodz428's Avatar
Troll Hunter
Arrow
Although you didn't post a picture, what I sespect you are looking at is the deain back hole for oil that goes to the cam gear, they are usually smooth since they usually have xcasting slag that's knocked out. It is these areas that get the work when a block is de-burred, I'd recommend doing it while the engine is down,
Old 02-03-2004, 08:15 AM
mstngjoe's Avatar
My 302 looked the same way. I cleaned it up with the Dremel during block prep.
http://hotrodders.com/gallery/showphoto.php?photo=5530
Old 02-03-2004, 12:42 PM
goose's Avatar
back to action!
mstngjoe and woodz428, thanks for the fast reply. even though my question was kinda vague, you guys nailed it. mystery solved.
Les
