Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - windstar trans/motor problem
Old 04-10-2004, 02:03 PM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
A code reader will do you no good unless you have a 'check engine' light on. A sensor can still give innacurate readings without setting a code. A trained tech will monitor 'live data' through a good scanner and watch for irregular sensor outputs to the PCM. If you can get live data and a manual that gives proper sensor outputs you may be able to catch something yourself.
BUILT FORD TOUGH
