winshield cutting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2004, 06:29 PM
winshield cutting
im thinking of chopping my 51 chevy sedan is there any way to take the front windsheilds and have them cut down. thay are rounded at the corners. if now how do you chop something with curved glass.
Old 03-15-2004, 06:46 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Big glass shops that do custom work, have a giant belt sander and they just grind them down.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 03-15-2004, 07:28 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
That's something I always wondered about myself.
Old 03-16-2004, 05:38 AM
kristkustoms's Avatar
First name...............Shawn
I believe if they are cutting them down alot, they cut them with a die grinder with a glass cutting disc. Then they sand the edges.
Old 03-18-2004, 03:36 PM
I have used a body grinder with a 36 grit closed coat sanding disk. Lay tape to the edge you want to finish at, and start grinding. someone with a garden hose dribbling water on it helps tostop the heat that can cause cracking. Just take your time and remember, you may distroy one or two before you learn the feel. I learned on side window glass from a junk yard cars before ever triing it on a windshield.
GOOD LUCK
