Unless you are going to start it and run it long enough at operating temperature to get rid of the condensation in the engine, you will be doing more harm than good by starting it. In most cases it is better to park it in the fall and leave it alone until spring. If it is going to be outside covered up. I would seal up the carb, breathers etc to keep moisture rodents, etc out. Drain the fuel out and run the carb dry. Check or change the antifreeze and change the oil if it is due.
Artificial Intelligence is no match for Natural Stupidity Chet |
How exactly would the carb be sealed up? |
Winter prep
Bob |
I usually run mine out of gas in October and put in fresh oil just to get the acidic oil out. I generally disconnect the battery and forget about it until April or May, whenever the weather breaks. Fresh fuel in the spring and I am off.
I'd bag/tape those as well. If it rains or snows a lot and you're opening/closing the garage, just more change of moisture entering the exhaust and corroding the pipes over time.
Bringing history and technology together. |
| Winter is here....what do do | Nightfire | Garage - Tools | 17 | 10-27-2011 08:12 AM |
| winter rod | ckucia | General Rodding Tech | 20 | 07-19-2010 09:43 PM |
| All The New Fun for Winter 305/307/350 | FKR | Engine | 1 | 10-17-2009 07:35 AM |
| I haven't seen this all winter | CrashFarmer2 | Hotrodders' Lounge | 9 | 04-24-2006 01:20 PM |
| Winter | Kevin45 | Hotrodders' Lounge | 6 | 11-25-2004 12:24 PM |
