Winters axle build
I have been collecting an Axle " one piece at a time" From E Bay. Now I realise it will not be easy to assemble without some help, So my Question is can any one recommend a site that is Winters specific , or even a site that covers sprint car axles in general, I already have lots of very interesting reading done on the internet, but still not finding the full picture.
PS I have been on the Winters Site +looked on the search function here too. |
Did you call them to see if a service manual was available?
Are you talking qc?Speedway catalog used to have a big picture of the rear end with all the parts. Sprintcars are different than other applications
I use the word "Hybrid" as im intending to use some European components IE. an Audi geared differential , that part of the project is just lathe work. What I will end up with is a very slim , and independent type axle,and cheap shafts( Audi again ), very strong and locally available,So its just the Winters part thats slowing me at present. I will try and post a few photos of all the parts, later. |
Still not sure what you are asking,there were independent qc made by some companies Most qc are close to the same and use the same parts.
What im hoping to find is any articles or sites that are dedicated to the subject, As an example if I was building a SBC 383 and googled up on that I would be swamped with endless information and specifications. |
Again I don't know what you are looking for,qc are different for ports car,stock cars and sprint car, spools, lockers, axles, axle tubes, hubs.
What size ring gear do you have?
The ring gear is 10" diameter and the Winters box says 4.5;1 . I am not under any pressure as this is hobby work, so I will keep looking Thanks.
10 inch ring gear is a sprintcar type ,What do you mean by the winters box reads 4.5; ?
There is a ring and pinion that is a 4.57,4.11,and 4.86 for a quick change with a 10" ring gear
Kaedings is a local sprint car shop in Campbell close to San Jose. They should be able to supply you with everything. Make sure you get a gear chart for the 4.57 so you know what final drive gears to get.
Lots of information here http://www.wintersperformance.com/catalogs.htm
| All times are GMT -6. The time now is 12:21 AM. |
