Winters axle build - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2011, 08:10 AM
Winters axle build
I have been collecting an Axle " one piece at a time" From E Bay. Now I realise it will not be easy to assemble without some help, So my Question is can any one recommend a site that is Winters specific , or even a site that covers sprint car axles in general, I already have lots of very interesting reading done on the internet, but still not finding the full picture.
PS I have been on the Winters Site +looked on the search function here too.
Old 06-17-2011, 08:22 AM
Did you call them to see if a service manual was available?
Old 06-17-2011, 10:19 AM
Are you talking qc?Speedway catalog used to have a big picture of the rear end with all the parts. Sprintcars are different than other applications
Old 06-17-2011, 11:30 AM
Hi thanks for your input, as it happens im a Speedway customer,and the components ive bought are for a "Hybrid" Sprintcar type axle im building, I do have the ability and the tools to set up an axle and many many successful axle build s done over the years.But absolutely no previous Winters experience, I have found one interesting Sand Racing site ,where a racer has made a similar axle to my plans, even E mailed him without any luck .
I use the word "Hybrid" as im intending to use some European components IE. an Audi geared differential , that part of the project is just lathe work. What I will end up with is a very slim , and independent type axle,and cheap shafts( Audi again ), very strong and locally available,So its just the Winters part thats slowing me at present.
I will try and post a few photos of all the parts, later.
Old 06-17-2011, 12:14 PM
Still not sure what you are asking,there were independent qc made by some companies Most qc are close to the same and use the same parts.
Old 06-17-2011, 01:37 PM
Ok, your kind reply is not really a question, but its information on QCs ,and informing me that an independent QC is available, With that information I Googled the subject( Independent Winters QC.) and that helped my research and I have some more links to read later ,Thanks.
What im hoping to find is any articles or sites that are dedicated to the subject, As an example if I was building a SBC 383 and googled up on that I would be swamped with endless information and specifications.
Old 06-17-2011, 01:42 PM
Again I don't know what you are looking for,qc are different for ports car,stock cars and sprint car, spools, lockers, axles, axle tubes, hubs.
Old 06-17-2011, 01:56 PM
Hi , your pretty quick with your response. I see you are in CA. I have a brother there , he went out there for 6 months, about 20 years back . Loves the lifestyle, unfortunately he does not share my interest in things mechanical.Anywayback to the subject of the thread. The first specific question I need an answer for is How many different ratios will fit into a sprint QC ,I notice only 2 ratios on most retail sites ,Speedway ETC. but I have ratio(CWP) 4.5;1 Thats not listed , maybe its for a Midget Winters QC. THIS IS THE TYPE OF INFORMATION IM SEEKING. Phoning is not an option as its too expensive also im short of hearing.I have sent E Mails to many retailers Winters included , But no replys, Might be my location.
Old 06-17-2011, 04:51 PM
What size ring gear do you have?
Old 06-18-2011, 10:30 AM
The ring gear is 10" diameter and the Winters box says 4.5;1 . I am not under any pressure as this is hobby work, so I will keep looking Thanks.
Old 06-18-2011, 02:54 PM
10 inch ring gear is a sprintcar type ,What do you mean by the winters box reads 4.5; ?
Old 06-18-2011, 03:09 PM
There is a ring and pinion that is a 4.57,4.11,and 4.86 for a quick change with a 10" ring gear
Old 06-18-2011, 04:20 PM
Thanks, so I have the 4.57, its brand new , and still in the box/carton , it came in.This evening I spent a few hours researching on the internet, and found ,http://www.kaedings.com/index.php?ma...index&cPath=19 .I have a list sent to them for the parts that will allow me to assemble my project, so hopefully next week I can make more progress.I also found a Circle Track magazine article.
Old 06-18-2011, 04:25 PM
Kaedings is a local sprint car shop in Campbell close to San Jose. They should be able to supply you with everything. Make sure you get a gear chart for the 4.57 so you know what final drive gears to get.
Old 06-18-2011, 04:38 PM
Lots of information here http://www.wintersperformance.com/catalogs.htm
setup on a winters Q/C Bad Rat Transmission - Rearend 7 02-02-2010 12:04 PM
Winters Intake ID scott657 General Rodding Tech 4 02-11-2009 02:04 AM
Winters QC Diff -- How to quiet it down???? Sidn Hotrodders' Lounge 14 08-16-2007 09:29 AM
Winters A comin .. i need help! "70" Cougar Hotrodders' Lounge 14 10-16-2004 08:51 PM
Winters Aluminum Intake. Coleman396 Engine 4 09-08-2003 03:31 PM
