Winters Intake ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2007, 09:45 AM
Winters Intake ID
I have a Winters foundry Manifold with the snowflake logo, and the firing order, on the bottom it has 2 numbers
701R-38
300-38
The 300-38 Jives with a Holley # but there are no Holley markings
There is also a casting # 01054 on the bottom
Its aluminum, Any help would be appreciated
ID:	18402   Click image for larger version
ID:	18403   Click image for larger version
ID:	18404   Click image for larger version
ID:	18405   Click image for larger version
Old 02-10-2007, 03:13 PM
Is it possible this is a factory aluminum manifold? After all, for many years Weiand made all of GMs aluminum manifolding especially the multiple carbureted ones. I don't remember ever seeing an aftermarket manifold with the firing order cast into it.
Old 02-10-2007, 04:19 PM
I guess it could be, I was thrown of by the Holley #
Old 02-10-2007, 04:45 PM
MI2600's Avatar
Member# 3287
All the Winters intakes I've seen have the snowflake on one of the front runners, plus they have the oil filler tube.
Old 02-11-2009, 02:04 AM
Winters intake identification
I just came upon this topic and hope there is enough time to help. The Winters harolding on your intake, and the Holley numbers don't conflict each other, both clues are right on the money. Many experimental and R&D pieces were made by Winters for Holley. Weiand and Holley had successful projects included into regular production, the firing order being present on some but omitted on others was common. I myself have a very rare and discontinued spreadbore intake made by the Winters foundry but was marketed as a Street Dominator series for a late 70's Toyota 4 cylinder. These were intended for 9,000 rpm zingers with insane valve overlap. How else would 134 cubic inches utilize the CFMs of a spreadbore? Rice flows different than dinosaur farts I guess. Some ponystock rules in the early days specified that a stock manifofold be used, and firing order casted on them was a loophole. The deep skirt block, forged steel crank, and rods that were bigger than a smallblock V8, had alot of people testing the limits of these indestructible little Saki-suckers on the dirt circuit.
QUICK! I have ONE HOUR! Will this Intake work??? Dizturbed One Engine 3 05-14-2005 09:10 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
Dart intake? Brodix or Dart Heads? Slowass72 Engine 3 01-20-2004 04:52 PM
(winters) tri power intake bb chevy prostreet silverado Engine 3 01-03-2004 06:18 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
