wiper arm stops at vertical position - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2008, 07:57 AM
Slickriffs's Avatar
This is not a problem on my 55 project truck but my sisters '90 Ford Probe. When the wipers are turned off they both stop in a vertical position. They had been working fine. Is this a switch problem? Would taking the arms off and re-installing them in a horizontal position fix this?
Thanks guys...Merry Christmas
Keith
Old 12-22-2008, 08:48 AM
Wiki Edits: 27
wiper parking
Moving the arms would make them wipe your hood. Inside the motor most wiper motors have a half moon type contact... when you turn off the switch the half moon is still contacted with ground usually until the arm moves to the park position. it moves past by inertia until it no longer has electrical contact and the arm stops. on some cars you can check by turning off the key when the wipers are up .. if you are fast with the key the arms stay up. check wiring connections and grounding of the notor.
Old 12-23-2008, 09:37 AM
Slickriffs's Avatar
Thanks Tim-I'll look into that.
Keith
Welding info Kevin45 Body - Exterior 10 08-26-2011 09:09 AM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Wiper transmission - 60 Vette KENMO General Rodding Tech 0 06-23-2008 09:48 AM
Wiper motor stops mid window when off! bonuts Electrical 5 10-10-2007 05:41 PM
Wiper Arm length 78 monte Body - Exterior 1 09-14-2007 11:14 PM
