wiper conversion help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 01:07 AM
hello hotrodders . nice to be in the " normal world " for a change ! building a 51 F1 on a 68 chevy p / up frame and running gear and am trying to keep it all original GM . tired of hearing both sides complain about the mix n & match n . no problems as of yet . Will need some info if available on using a GM wiper w/ delay for the GM column installed on the truck . year or type would be helpful if any one has converted one from vacuum style . wanted to use original transmission arms if possible . any help will be greatly appreciated . Will eventually modify to fit a factory replacement wiper motor
Old 08-03-2011, 11:51 PM
dinger's Avatar
I have seen a few modified to work in older vehicles, some cutting and welding might be needed to get the right set up. Fit the motor as close as you can fit the arms, one or the other will have to be modified. Your skills and tools will determine much of this.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
6 to 12 v wiper knighthawk Electrical 1 08-02-2009 01:17 PM
elctric wiper conversion knighthawk Electrical 1 06-11-2009 08:20 AM
electric wiper conversion squidward Electrical 19 06-22-2006 11:16 PM
winshield wiper conversion headaches. jcarter Body - Exterior 12 02-18-2006 12:40 PM
57 chevy wiper conversion romine Electrical 2 12-11-2004 01:06 PM
