wiper delay module or motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2009, 12:13 PM
fast68's Avatar
likes chevy trucks & boobies
ok we have an 85 elky it has the CD4 intermittent wipers with the circuit board module on it 22038486
if you run the motor alone on a battery on the bench both low and hi work fine and it sounds nice
yet on the car all assembled the motor doesnt act right
how can you determine what is wrong and where can you find another module like this ?
no yards here are any help
any tips would be great
thanks
Old 07-29-2009, 02:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If assembled back on the car, the wipers will work on the intermittent setting sometimes, sometimes not- and the switch detents don't seem to have an exact or repeatable effect on the wiper delay, it's prob the switch portion of it. At least that's been my experience in the past.
The switch can sometimes be brought back by spraying it out w/electrical contact cleaner REAL good (Radio Shack carries it, can't use carb cleaner, etc.- will damage some plastics).
If there's NO intermittent action, regardless of switch position (jiggling, setting half way between detents, etc.) then the CB/module circuitry could be bad.
I'm not sure what you have going on, though- are the wipers OK in "regular" low and high, etc., but not working on intermittent?
Old 07-31-2009, 08:00 PM
Is this the module that you have?
Old 08-21-2009, 06:22 PM
fast68's Avatar
no that is not it
hmm ill have to pic it and show ya
motor works fine hi and lo speeds by itself
thanks
Big Block/Windshield Wiper Motor MWG General Rodding Tech 3 09-25-2008 08:24 AM
wiper motor on 71 GS mcpdllc Electrical 0 05-27-2008 07:42 AM
Wiring New Port wiper motor to GM column bnewsom Electrical 1 08-25-2007 06:43 PM
wiper motor wiring 37 plymouth coupe Electrical 4 07-27-2007 11:30 AM
Wiring a Volkswagon wiper motor wheel-7 Electrical 4 07-01-2007 06:18 PM
