wiper help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2009, 12:18 AM
dot 5 blinker fluid
wiper help
i have a 79 chevy impala i know this sounds crazy my wipers wont work when hooked up properly, when i flip the plug upside down at the motor they work when turned off but only 1 speed when i turn them off they go up 2 inches and back down any idea what to try ive replaced the wiper motor and the switch with no results ive got good ground. thanks bert
Old 06-10-2009, 08:40 AM
The 2-speed GM wiper motor uses what's called a shunt winding to get the low speed. There is a primary motor winding for high speed. The shunt winding is wound in the opposite direction and partly negates the high speed winding to provide low speed. This reverse wound shunt winding is also used to park the blades when you shut it off. If you've already replaced the switch and the motor, you have a broken wire someplace between the two.
Wiper transmission - 60 Vette KENMO General Rodding Tech 0 06-23-2008 09:48 AM
Voyager wiper issues SAATR Electrical 5 03-09-2008 07:50 AM
wiper motor won't run cboy Electrical 14 05-03-2006 10:44 AM
jeep rear wiper motor wiring themodernartist Electrical 2 12-10-2005 08:14 PM
69' Camaro - Need Wiper Motor Replacement Advice PrimaDude Engine 2 10-29-2005 07:08 AM
