Originally Posted by ogre
interesting looking motor; a gearbox on each end and stiff arm to hold everything together.
you don't say what model truck you have, but i've never seen a 52 anything that didn't have vacuum wipers on it.
i'd almost bet that is a 12 volt conversion, look carefully at the motor for any markings
It is a factory Ford motor made bt American Bosch. Outstanding system, with no new parts available. It was not common on pickups, but the bigger models, F4, F5 ect. used it a lot.
Years ago when I had a pickup with that setup.I used a rheostat type heater control under the dash between the power supply and the wiper switch set to output 6.5 volts under load.
Today, I would use a solid state voltage reducer like this
VW Ignition System – Volkswagen Alternator | AppleTreeAuto.com
