wiper motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2009, 10:05 PM
carsn's Avatar
wiper motor
ok i am trying to find a wiring diagram for a wiper motor on our 1961 impala, i know that it has a ground switch but im trying to figure out how this goes. so ill take any thoughts.
Old 12-11-2009, 03:59 PM
Joe G's Avatar
Originally Posted by carsn
Ok I am trying to find a wiring diagram for a wiper motor on our 1961 impala, I know that it has a ground switch but I'm trying to figure out how this goes....
I don't have a wiring diagram handy, but I may be able to help you figure it out if I can get a little more info from you:
Which end are you trying to hook-up, the motor or the switch or both?
Is there any wiring, or is it all missing?
Old 12-11-2009, 04:48 PM
Guest
On the lower side of the motor there is usually male disconnects, i think the lower right will be brown (12v supply), next to it will be red, this red goes to the switch and jumps to the other connection point above the motor (to the lower of two male disconnects), a black will go from the switch to the upper male disconnect of that same connection point. I don't think this motor 'parks' does it?
I know that ground plays a role and whether that is an internal thing thru the switch isn't clear from my schematic. I'd mock it up on a bench first to try it. Hope this helped, oj
Old 12-13-2009, 12:26 PM
carsn's Avatar
Im trying to hook up the motor to the switch. i have all the wiring,but i think someone spliced i couple wires in.
it does park, i know it has power to it at all times. it is just the ground switch that is throwing me for a loop.
Old 12-14-2009, 12:55 AM
Joe G's Avatar
There should be a set of three terminals on the wiper motor; One is wired to fused key-on power, and the other two are wired to the wiper switch. The wiper switch controls the wiper motor by grounding these two wires in different combinations.
When:
Only wire "A" is grounded, the wipers run in high
Both wires are grounded, the wipers run in low, and
Only wire "B" is grounded, the wipers park.
There is a third terminal on the wiper switch that triggers the windshield washer by grounding a wire from the washer pump. The windshield washer pump is mounted to the wiper motor, it has a set of two terminals; one of them is wired to the wiper switch, and the other has a short wire to the power terminal in the wiper motor terminals.
I think I have a wiper wiring diagram from a '63 Corvette. It uses the same wiper motor and switch as your car, so I think it's safe to assume they are wired the same. I'll scan and post the diagram tomorrow.
Hope this helps....
Old 12-14-2009, 06:28 PM
Joe G's Avatar
Well, I couldn't find the wiring diagram I was looking for. So I made one.
Hope this helps...
Old 12-14-2009, 08:11 PM
carsn's Avatar
thanks for all this info. and yes it did help we now have everything wired up and everything works great. thanks for helping.
Old 12-15-2009, 07:43 AM
Guest
Great drawing Joe G, closest schematic i had was for a corvair and yours is much clearer, i saved it for future. Thanks, oj
Old 12-23-2009, 02:23 AM
New Member
nice post dude ......
i have no device like this ,
but i am trying to collect like this ......
thanks for your post dude ...........
new steering part search
looking for wiring for 2 speed wiper motor on 68 chevy pickup trkitchens Electrical 1 03-20-2008 07:12 PM
Wiring New Port wiper motor to GM column bnewsom Electrical 1 08-25-2007 06:43 PM
wiper motor wiring 37 plymouth coupe Electrical 4 07-27-2007 11:30 AM
wiper motor for 37 ford Sedan bgal Electrical 1 12-21-2002 03:20 PM
GM wiper motor color codes. JOHND. Electrical 0 12-10-2002 06:03 AM
