Wiper motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2011, 10:33 PM
Rag top bird's Avatar
Hot rods are still the king
Wiper motor
I have a 91 firebird and I am trying to find out if the motor is bad and I need to know what wire to test to see if it is getting power to the motor I have 6 wires going to the motor
Old 05-06-2011, 11:39 AM
looking for wiper motor on 55 international R110
Old 05-06-2011, 11:55 AM
You mean like this one?
http://cgi.ebay.com/ebaymotors/1950-...Q5fAccessories
Old 05-06-2011, 01:49 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The attached schematic shows the wiring for a typical GM wiper motor.
To test it connect the white wires to 12 volt +.
Connect the case to ground. Black wire.
Connect the purple and gray wire to ground and the motor should run in slow speed.
Connect the purple only to ground and the motor should run in high speed.
Connect the gray only wire to ground and the motor should park.
Connect the pink, purple and gray wires to ground and the washer pump should engage and run.
When the washer control switch is pressed the slow speed switch is activated.
vicrod
bad gm wiper motor? ckliever Electrical 8 09-22-2010 03:39 PM
wiper motor carsn Electrical 8 12-23-2009 02:23 AM
wiper motor smrat Electrical 2 07-19-2008 04:18 PM
Wiper Motor Jude-Racer General Rodding Tech 3 09-29-2006 10:39 PM
wiper motor won't run cboy Electrical 14 05-03-2006 09:44 AM
