wiper motor in 82 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2004, 12:51 PM
when i use the wiper motor, it will not shut off and when i use the windscreen fluid, it will stop pumping
any ideas what it could be?
Old 12-15-2004, 10:27 AM
poncho62's Avatar
Wiki Edits: 5
The windshield vwasher pump runs on a little cam device in the housing which is probably sticking.
Also, check your ground to the motor, .................
Old 12-15-2004, 11:08 AM
Restore60s's Avatar
wipers
If the grounds check ok, could be the park switch in the motor also.
