wiper motor wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2007, 01:30 PM
37 plymouth coupe's Avatar
wiper motor wiring
installed a new (universal type) electric wiper motor in my coupe. The motor has a label "automatic park". The wiring hookups have three terminals (+)
(-)(S). I am using a toggle switch to activate ( only two wires) and the auto park feature does not work. How do I wire this to take advantage of the "auto park" feature?
Old 07-26-2007, 03:16 PM
Not A T 25's Avatar
Takes Guts To Cut One Up
If I remember right Power to the (+) and ground to (-) and the feed to your wiper goes to (S) but it has been a while be ready to replace a fuse I think I have the paper from mine in a pile at home I will look but if you have an Ohm meter you can figure it out pretty quickly.
Old 07-27-2007, 08:32 AM
Frisco's Avatar
Glad To Be Here
The correct wiring for the "Universal" wiper motor is:
The negative terminal (-) goes to ground.
The positive terminal (+) goes to a fused power source.
The switched terminal (S) goes to one side of a toggle switch and to ground from the other terminal on the toggle switch.
If you have a "Mighty Wiper" brand the wiring is not as above. Their unit is wired quite different and will not work for the "Universal" wiper motors that are so prevalent. I am running the "Universal" style wiper motor.
Old 07-27-2007, 10:55 AM
Not A T 25's Avatar
Thanks Frisco if he had followed my directions he would have gone thru a box of fuses I wasn't able to find the directions from my switch last night
Old 07-27-2007, 11:30 AM
wiper motor wiring
Thanks guys....that makes sense...going out to rewire now.
Can you identify this aftermarket wiper motor? RodFather General Rodding Tech 2 06-25-2006 09:52 AM
wiper motor won't run cboy Electrical 14 05-03-2006 09:44 AM
jeep rear wiper motor wiring themodernartist Electrical 2 12-10-2005 07:14 PM
69' Camaro - Need Wiper Motor Replacement Advice PrimaDude Engine 2 10-29-2005 06:08 AM
Wiper Blades RCastle General Rodding Tech 9 02-01-2005 03:09 PM
