Wiper motor wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2012, 11:46 AM
Dimwit
Last journal entry: S10 fabrication (cont'd)
Wiper motor wiring
I have three wiper motors in hand for use on my build and am not confident that any of the three will work. I need help figuring out whether I will be able to wire any of the three properly.
Motor #1 is from a 2005 Silverado. I have the motor, the wiring connector and a good bit of the wiring harness, but I do not have the steering column, the switch, or the firewall-mounted computer module that accompanies the system. I have located several wiring diagrams for this model, but none appears to tie directly to the wire colors on the connector.
Motor #2 is from a 1995 S10. I have the dash-mounted switch and a good bit of the wiring harness for this vehicle, but have misplaced the connector. I have a wiring diagram for this model, but have no idea how the 5 pins in the connector relate to the wire colors in the diagram.
Motor #3 is from a first-generation S10, specific year unknown. It has a four-wire connector attached. I have not been able to locate a wiring diagram for this motor.
I know I can get a new "Clean Wipe" motor with wiring instructions and a switch from Newport Engineering, but I'd prefer to spend the $200 elsewhere given the three motors I already have.
Does anyone have thoughts on how to get any of these three motors to work?
ID:	70002   Click image for larger version
ID:	70003   Click image for larger version
Old 12-23-2012, 12:10 PM
Here are some diagrams that may help. The 05 Silverado requires the body control module to park.
The Following User Says Thank You to crownver For This Useful Post:
Supercharged03 (12-23-2012)
Old 12-23-2012, 02:20 PM
Dimwit
Thanks, crownver.
Update. I've located the s10 wiper motor connector. I now have the complete harness from the steering column switch (not dash-mounted - I mistakenly was thinking of the headlamp switch in my first post) to the wiper motor. Maybe this won't be as difficult as I am thinking.
I can't believe I've spent a month looking for that thing.
wiper motor wiring help wmwise Electrical 2 12-23-2011 02:14 PM
Wiper motor wiring johns79camaro Electrical 15 03-25-2011 05:46 PM
wiper motor wiring 37 plymouth coupe Electrical 4 07-27-2007 11:30 AM
wiper motor wiring ceiling-tiles Electrical 6 08-16-2004 10:02 PM
wiper motor wiring - gm column -- HELP PLEASE!! gtofloyd Electrical 2 11-11-2003 11:10 PM
