Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiper motor wiring help
Old 12-23-2011, 02:14 PM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
red is hot. black is ground. one ground will make it run, the other ground will make it park and is always grounded. you will have to try grounding each one separately. if it runs for a bit and stops, ground it with a screw. if it runs, ground it through your wiper switch.
