wipers arent working properly - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2007, 03:54 PM
elcaminodragster's Avatar
70 El Camino aka FRANKENSTEIN
i have a 70 elky and the wipers dont work properly. i turn them on (low or hi) and the arms go up a few inches and go back down. it seems like the arms might be jumping on the teeth or something im not sure. the wiper arms and where the hook up is in good shape but underneath maybe??? the motor is brand new.
its the hidden setup.
Old 09-21-2007, 08:20 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Sounds to me like a screwed up set of contacts in the wiper motor. (edit: stuck in 'park')
When the wipers are switched off, there is a set of contacts that maintain a path to ground while the wipers 'park'
This sets off another reaction that actually "parks" the wipers. Actually it kinda activates a cam.
Pretty much all of these motors work the same, the hide-aways most likely just use a different cam to park them.
If it is a 'new' motor, it is most likely a rebuilt motor that has set on the shelf for quite some time and the contacts have some 'crap' on 'em.
Same thing happened to me. the vendor I bought the motor from had it shipped from the rebuilder. Wish I could remember his name. He kinda explained to me what was actually going on. He even walked me thru the fixing to get me going 'til he could get another out to me.
He sent me a new motor on the 'honor system'. He just asked me to return the first unit upon delivery of the replacement.
When I get home I will see if I still have his number somewhere.
Bryan
Old 09-21-2007, 10:07 PM
i think i have narrowed it down to it being the switch. when i turn off it does the same thing when i turn it to low speed its on high and when i turn it to high it slows way down. i think it might be the switch.
Old 09-22-2007, 08:20 PM
Bryan59EC's Avatar
All connections to the wiper switch are a ground of some sort.
The power feed is direct to the motor from the fusebox (key on)
Try disconnecting the wires from the switch and ground them individually.
One should be 'low'-------one should be 'hi' ----and one may be 'wash'
Bryan
Old 09-24-2007, 01:30 PM
The GM wiper motor uses a shunt winding wound in the opposite direction to both provide slow speed and park. When the contacts in the motor go bad, you get the pulsing motion you've described. It's happened to several of my cars and always required a new wiper motor to fix it.
Old 09-24-2007, 08:57 PM
the motor is new and i connected all the wires but not the wiper arms and it works spins in a circle no odd noise. i connect the arms and it pluses the arms. the motor still spins all the way around but the arms pulse .
also when i turn the motor off by the switch the motor stays on.
Old 09-25-2007, 11:49 AM
Did you replace the ground strap? The GM wiper motor is isolated in rubber bushings and there's a separate ground strap that goes around one of the bushings.
Old 09-25-2007, 12:27 PM
yes the ground strap is good.
Compressor and piping all working finally Danny G. Garage - Tools 3 06-21-2006 09:12 PM
#1 Cooling Fan Not Working Properly?? Willy1 Electrical 4 05-05-2006 03:51 PM
Oh how I miss working in the garage.... FrankR Hotrodders' Lounge 9 03-01-2006 11:40 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Speedometer not working??? Mightymouse Body - Exterior 2 06-24-2004 04:41 AM
