wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2009, 11:13 PM
wire
What type of wire is used around the base of the facing on a benchseat for hogrinring the the cover to the frame. do you sew it in or slide it through the cover after sewing?.......Steve
Old 09-28-2009, 05:16 AM
BOBCRMAN@aol.com's Avatar
1/16" welding wire will do in a pinch. Sew the piece, then insert the wire.
Old 09-28-2009, 07:13 AM
DanTwoLakes's Avatar
Wiki Edits: 22
There is nothing special about the wire, it is just about 12 or 14 gauge malleable steel wire, and it is put into listings, which are just pockets for the wire sewed to the seat cover. You can also use stake wire, which is paper covered oil impregnated wire. You don't necessarily need to use wire, you can use Typar listing with cord in it. It comes in different widths and in rolls or by the yard. The Typar listings also come without the cord sewed in, here is a link for that: CLICK HERE I like the listing with cord because it turns corners better than listings with wires in them.
10si wire help monte ss Electrical 6 08-03-2010 06:26 PM
Fried wire from ignition to soleniod? frankenvette Electrical 4 07-31-2008 02:45 PM
Help with Digital Dash Install jvgrago Electrical 4 05-16-2008 07:16 PM
Another question on fusiable links oldred Electrical 5 06-16-2007 03:12 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
