Wire Brush - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2009, 07:20 AM
Wire Brush
I am stripping the paint from the tail panel (behind tail lights) with paint stripper and finishing up with a wire brush in a drill. The panel is intricate, so it would be impossible to sand with a DA. Will the wire brush leave a surface finish thats okay for primer, or do I need to hand sand it? What about a surface cleaning disc in a die grinder? I just finished handsanding the underside of the trunk lid,and I don't think my fingertips can handle any more intricate sanding for a while
Jamie
Old 03-18-2009, 07:51 AM
cyclopsblown34's Avatar
Colorsanding painter
The wire brush should leave a nice surface for epoxy primer to bite into. You don't want to get any finer than 80 grit when applying epoxy primer.
Old 03-18-2009, 07:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't know why I thought the finish should be finer than that.
I know what I'll be looking into, next time.
Old 03-18-2009, 09:01 AM
Supposedly any finer and the epoxy won't have anything to bite into. I just found this out the last couple of months.
Fried wire from ignition to soleniod? frankenvette Electrical 4 07-31-2008 03:45 PM
Help with Digital Dash Install jvgrago Electrical 4 05-16-2008 08:16 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 05:22 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 04:39 AM
Sanding w/ wire brush? spookabilly Body - Exterior 14 07-03-2003 04:39 PM
