-   -   wire harness (http://www.hotrodders.com/forum/wire-harness-126201.html)
wayneo 10-13-2007 07:08 PM
wire harness
ok so i picked up a wire harness at the salvage yard for my S10 with luck i can get this started soon
302 Z28 10-13-2007 09:00 PM
IMO you are getting off to a bad start. Why a salvage yard harness?
Vince
Crosley 10-14-2007 08:11 AM
I used salvage yard wire harness sections once.
I've done plenty of things once. Then learned a better way.
Are you replacing / repairing the original harness in the S-10?
Good luck
joe_padavano 10-14-2007 10:51 AM
Vince
I've had no problems with used harnesses. Here's a news flash - the harness in the car you have now is "used" also. If the wrecked car was hit in the rear and you're taking the engine harness, chances are there's nothing wrong with it. Obviously, check for corroded connectors and melted connector bodies. Other than that (and obvious tampering by previous owners), the plastic insulation and connectors probably isn't going to go bad. If nothing else, this is a very economical source of connector bodies for your own harness rebuilds. Correct terminals are available from a number sources.
302 Z28 10-14-2007 06:42 PM
The chance of getting a salvage yard harness that has had problems is too great. Sure the reason that vehicle is in the salvage yard is not the wiring, but how do you know if the fuse panel connections have been compromised or certain wires in the bundle have not been over heated. A new aftermarket wiring harness is too cheap to be cutting corners on a salvage yard harness as far as I am concerned.
Vince
joe_padavano 10-15-2007 07:43 AM
Vince
Hey, it's your money, spend it any way you want. Me, I've never had a problem with a used harness.
