wire harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2007, 04:57 AM
wire harness
ok is there an easier way to get my S10 running again do i really need all these wires (there is like 100 miles of wire here just start the truck ) it has a 350 with Hei dist. the wire harness i got from the salvage yard is hooked up but which wire goes to the dist? the 6 cly harness has two plugs for the dist ( i figure ok easy no problem, with the key on there is only one orange wire with very low power to light my test light.i tryed it it doesnt do anything. they havent changed the wire harness colors so which wire(s)did you V8 S10 owners use cut into to run to the dist. hey anyone live near cherry hill NJ area ill pay you if you help me figure this out thanks wayne call 856 313 1079 this ran before *** am i doing wrong I HATE wires
Old 10-18-2007, 05:59 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
On a GM HEI there are 5 Spades on the Dist cap
3 into the back {or closest to the dist } & 2 further away
the 3 in the back go to the Dist.
The other 2 1 is the power the other 1 is for the tack if you look closely it will say on it tach.
To "just get it running" hook the power wire to some power then it is live .
Keep in mind that it will stay on until the power is interrupted.
Then all you will need is a jumper wire to the starter to crank it over .
Assuming you have a battery cable going to the starter.
Does this help?
R
"SlowRide66"
"Illegitimis non carborundum"
Electric choke voltage Mertz Engine 36 04-22-2007 11:28 AM
'68 Chevelle: need wire harness Bort Engine 3 04-10-2007 04:01 PM
aftermarket harness = confused Blob Electrical 7 10-18-2005 07:51 AM
wire harness to firewall connector pin bent 66Caprice Electrical 12 07-10-2004 07:40 AM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
