Hotrodders Bulletin Board
#1
wire me up
Howdy guys. Just a quick general question? I'm wiring a 52 international
pick em up from scratch (355 chevy/4speed etc.). My question is!! what amp fuse and what guage wire for: headlights, ignition, ignition to coil, gauges and electric fuel pump? I have a fuse block from a dodge mini van, most of the fuses are 10 amp with fairly small wire coming out the back, looks like 16 or 18 gauge wire for the most part. There are 3 20 and one 30 amp fuses with 14 or 16 gauge coming out. What would be safe, obviously I'm trying to do it without spending bucks on a generic wiring kit, I got a lotta wire, and a good soldering gun, so what should I do. Thanks so much in advance, this board is always great. Opps: p.s. alternator to battery in line fuse and wire gauge? The Tim guy somewhere in the ozone in Virginia |
#2
re: wire me up
Doc here, HEAD LIGHTS: unless your planning on running relays, (recommended) , Run 10 gauge wire from the switch to the buss, to the lamps..lot of current draw! Headlamps are not generally fused at all..most have thermal resets inside of the headlamp switch, Short of that, run a 40 amp fuse link from the source to the switch or HI/LOW input. IGNITION: 10 gauge wire.stock is usually 12 to 14 gauge, UPGRADE it to 10 gauge wire..a Stock coil under full load will pull 15 to 20 amps..IF you upgrade sometime later to a performance coil, it may pull as much as 48 amps under full load. Your $600 Performance Ignition may run worse than stock BECAUSE of current starvation to the coil..and your stock ignition will perform better than ever. IGNITION wires are NOT generally fused..but protected from the fuse link on the ignition switch "Hot AT ALL TIMES" side of the switch (the main buss link) ALTERNATOR: 10 gauge wire for BOTH the output wire and a ground wire attached to a proper ground buss system. The fuse LINK will depend on the output of the alternator, for instance , if it is a 63 amp alternator, The FUSE LINK will be 70 amps. DO NOT use a standard fuse here, unlike a FUSE LINK , which requires TIME and heat to open the junction, a fuse wil just continue to blow, every time the charging system spikes. until you hopelessly over fuse the system, this leads to fires. GAUGES: Provided you run nothing else off the gauges line ( Radio, lighter, etc.) run a 14 gauge wire for this line..it may be fused as low as 5 amps, but 10 is acceptable. FUEL PUMP: you need to look at the fuel pump to find the draw of the specific pump motor, You may need a relay (recommended). If less than 20 amp continuous, you may run 12 gauge wire, And get away with it..BUT I'd run 10 gauge wire, that's one long run of wire that you don't want to starve for current to the device..and it will run better..(bigger is better) IF it is more than 20 amp, you should run 10 gauge, run a relay (recommended) from the pump to the relay, and control the relay with a 14 gauge wire fused , off rhe switched buss at 5 amps. Relays on high draw items are the way to go since your upgrading the whole system anyway.. Your switch gear will last forever, (no direct draw through the switch, but through the relay.), The user device will perform up to 3 times better, (headlamps up to 3 times brighter, Coils that perform flawlessly, motors that run faster and torque harder, (fuel pump working at max power, no line loss) The use of 10 gauge wire allows the easy flow of current from the source (battery) to the device (load) Without heat loss within the wire or switch gear (Current producing no useful work, and converting it to heat). JUST as important , you need to set up a proper ground buss system, this is how to do that: For your Ground Buss, Set it up as follows: BE sure First, You have A 4 gauge Cable (for stock battery location, OR , 0/0 or 0/1 Cable for a trunk location) from the battery, to any handy bolt at or NEAR the starter on the block . Using a short run to something like a seat belt bolt, or body bolt just adds resistance, the body is insulated..(has road paint and sits on rubber mounts) this , makes for a "Poor or no" Bonding situation..
To install a proper ground buss system, This MUST be done:
HOW TO MAKE WAY DURABLE CHEAP GROUND BRAID: --------------------------------------------------
This will be your braid cable, just Cut to smaller length's as needed, and tuck the cut ends into a crimp terminal and crimp the ends on.. IF you can Solder, Tin the ends before you tuck the ends of the cable into the terminals, then Tin the barrel of the terminals, then insert the cable and crimp.. Then heat the terminal and braid, feed some solder into the opposite end as the heat is being applied, let it melt and FLOW or WICK toward the heat..until the terminal barrel is filled and is smooth and shiny.. that is a good joint..gray and rough is a "Cold Joint" and you'll have to start over..
It sounds like a lot of work, but after you assemble all the parts, it's only a few hours to do..and you'll end up with a system that will work reliably for many years to come..and can eliminate that from your troubleshooting list. Remember: GROUND is the other Half of your 12 volt circuit AND is equally as important as having POWER to the device! Doc ![]()
Aftermarket Solutions Electronic & Electrical Innovations |
Back to top |
Similar Threads for: "wire me up"
| new welding wire | oldred | Body - Exterior | 88 | 10-10-2007 10:15 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 19 | 06-28-2007 12:42 PM |
| 1986 Cutlass wiring Q's again :( | ChrisMiddleron | Electrical | 12 | 07-16-2005 03:22 PM |
| One wire or three wire? | Screwy Lewy | Electrical | 0 | 06-30-2003 03:33 PM |
| 57 Chevy generator to altenator swap | Rodrunner | Electrical | 2 | 07-17-2002 08:59 PM |
