wire short or pump short prob - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2003, 08:51 PM
ok theres something wrong with the fuel pump i know but every now and then along with a bad battery when i get out and take the keys out i can go inside and come back out klater i hear the sound from the take like my pump is running like when you first turn the key on..... it keeps killing my batter how do i fix this or you know find where exactly the problem is if ya need more info about the prob email me
Old 10-02-2003, 09:14 PM
dmorris1200's Avatar
doesn't play well with others
To start with I would suggest reading our Guidelines located at the beginning of every forum.
Hotrodders Guidelines -- READ ME
Since you gave no worthwhile info I will simply give you the most general answer I can give. Next time you think the pump is running without the car on pull the fuel pump relay and see if it stops running. Sounds like a relay sticking on, you could try swapping it with another relay.
BUILT FORD TOUGH
Old 10-02-2003, 09:17 PM
type of car
its a 1987 fiero coupe if that helps forgot to put that in there i know these cars have alot of probs everyone keeps telling me that i dont really care a friend gave it to me and asked i put some time in it cause he could so.. now i m restoring it
