Wire Size
Hey guys,
I just purchased this Quincy 5 horse, 60 gallon compressor from Norther Tool. It's being delivered this week so I don't have any paperwork yet. There is a FAQ section in the description of the compressor and one of the answers is that it takes #10 wire along with a 30 amp fuse. I have a lot of #8 wire with a #10 ground in the shop. Can I use that wire along with the 30 amp fuse safely? FREE SHIPPING — Quincy Compressor Reciprocating Air Compressor — 5 HP, 230 Volt Single Phase, Model# 2V41C60VC | 19 CFM Below| Northern Tool + Equipment Thanks Dave |
wire'n the compressor
short answer is Nooooo problem... 30a use a 10ga wire and your going bigger.. go'n smaller is where the problem is.. skinny wire has a higher number, fat wire is a lower number... your more then ok...
You can use a larger wire size greater than #10 AWG on a 30 amp breaker. You cannot go smaller than #10 AWG on a 30 amp breaker. Going smaller would make the wire the fuse (so to speak).
#8AWG is larger than #10AWG Vince |
| All times are GMT -6. The time now is 02:39 AM. |
