-   -   Wired brake distribution block (http://www.hotrodders.com/forum/wired-brake-distribution-block-32878.html)
adb2f 01-26-2004 11:09 AM
What's the wire for to my distribution block on my '72 Cutlass with drum brakes all around? It goes into a white plastic piece but I didn't want to pull it and break something. Also didn't want to unscrew it and brake fluid shoot everywhere. What is it and how do you disconnect it?
Dave E Shank 01-27-2004 01:35 PM
HEY AD: Could it be the brake light switch? That should be the only electrical connection in a brake circuit....DAVE
adb2f 01-27-2004 01:59 PM
Yes that's it but how is it removed? Do you unscrew it or just pull it? I didn't wan't to break it. I inlcuded a pic below.
http://72chevelle.com/images/dispics/pic010.jpg
Wrencher 01-28-2004 05:31 AM
That switch will turn the light on in the event of a frt or rear pressure failure, I believe you pinch the widest part to remove?
troy-curt 01-28-2004 07:33 AM
Yep, it's the brake pressure failure warning light.
Just unplug.
Troy
