wireing 04 5.7 hemi with 700r4 trans 29 dodge 4 dr sedan - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-05-2012, 11:18 AM
I have org. factory eng harness & computer. I have adapded 700R4 trans,what kind of problems am I getting into not having harness plugged into a trans if any ? will eng.perform proper. I do have the org. 5 speed automatic trans but its big, heavy,and being computer control very pricey to repair !
Old 02-06-2012, 06:57 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Chances are it will run in a limp mode, not making full power as it sees a trans problem (due to there isnt one that it recognises.)
What would work is a pcm from a standard set up with your 700r 4 , eliminating the need for any feedback from the trans (other than VSS) to allow the PCM to strategise operations.
You may want to look into an aftermarket EFI controller that is tunable to allow fine tuning the power and driveability of the system.
Old 02-08-2012, 03:42 PM
EagleMark's Avatar
GearHead-EFI.com
Wonder if you could find PCM for manual trans? Chnaces are it would still need some programming to remove emmissions or body control modules etc... I really know of no one who does these but I'm sure there are?
I've seen MegaSquirt boards mounted inside many PCMs to look stock. Pretty verstile to tune, lots of options and may find one for TCC lock up below...
Then still have no lock up for TCC but that could be hard wired into switch for highway cruise.
Old 02-13-2012, 10:51 AM
5.7 hemi to 700r4 trans in29 dodge sedan
I have located standered trans computer which i've been told should correct my vech from going into limp mode . as far as emission for performance i have all sensor related to eng. and orig fact harness which i will cut down to fit my needs . i also have both ox sensor before converters. since im not running converters will this be a problem ? God knows what else i might encounter. looking for any advice to help me through this convershion. i'm starting to 2nd guess my self ken
Old 02-13-2012, 07:39 PM
EagleMark's Avatar
GearHead-EFI.com
O2 sensors before converter without converter will not be an issue. If the system has O2 sensors after conveter they can be modified to work fine.
Your going to need a VSS... proper fuel pressure and I don't know if that has a return line or returnless? EGR is a good thing. Charcoal canister purge can be dealt with. Need to get error codes for that engine and it will give you an idea of what is going to set if you don't have it. Like did it have a Power Steering pressure signal?
It's a worthy project and obtainable. You'll love the end result!
Old 02-14-2012, 07:12 PM
Wiki Edits: 49
I'm just curious here..... why not use Mopar's 545RFE five-speed automatic overdrive transmission? It bolts up to the hemi and is controlled by the hemis computer. On the surface this looks to be the way to go. Just wondering why you chose the GM trans.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 02-14-2012, 07:58 PM
Last journal entry: Some More Roll Cage Fabrication
Centerline
HotRodsAndHemis.com
X2
The 5 speed shouldn't cost too much to repair. Plus that five speed is going to give you better performance compared to the 700r4
Old 03-02-2012, 03:13 AM
late hemi
i've also got an 04 5.7 hemi and the 5 speed auto trans. i am using the auto trans that came with the motor only because i want to keep it simple. i got an 04 ram 1500 chassis/engine trans, less body and interior. street and performance in mena arkansas has been very helpful. i got their harness that lets me use the factory ecm and all sensors, etc. you know that in 04, there was one brain. unlike the 03 which had one for the motor and another for the trans. the next thing to attack is the throttle by wire. lokar advertises that they make a hall effect pedal that will work with gm, ford, and mopar. it'll power my little chopped and channeled 24 dodge coupe just fine. good luck with your project. as far as opinions, i think centerline has the right idea.
Old 03-02-2012, 03:22 AM
fuel system
the 5.7 fuel system is a straight pressure to your fuel rails. in order to use an aftermarket fuel pump, you can use a c-5 series fuel filter. it has one inlet from the fuel tank where you have your pump, and one outlet that goes forward to feed your fuel rails. it also has a return line that brings the excess fuel, the gas your motor won't use, back to the fuel tank. now the interesting part of why this works is that the corvette fuel filter not only filters the fuel, it also regulates the fuel pressure to the rails. fram makes them and they're the simplest way to regulate your fuel pressure. they're not expensive at all, so it's a win/win. look at "street & performance" website, and you can learn more. the filter cost me i think around 12 bucks. far cheaper than going with a specially adjustable pressure regulator, it does the job, and it's much simpler. i hope this helps.
Recent Modern Electronic Engines posts with photos
700 r4 for 1929 dodge with a 1955 dodge hemi ? rustfarmer Transmission - Rearend 4 12-15-2011 10:41 PM
241 Dodge Hemi Von MoPar Engine 1 10-14-2010 06:24 PM
700r4 Question on my wireing setup jtcfanof3 Transmission - Rearend 8 01-04-2009 11:07 AM
4L60E trans wireing questions imshaney45 Transmission - Rearend 7 11-28-2008 08:45 AM
700R4 wireing ? shiftkit ? omega69 Transmission - Rearend 2 05-27-2008 01:22 AM
