wireing instruction - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2012, 11:17 AM
wireing instruction
has anyone ever look that the back of there new fuse block to see were the incoming power line's or hot wire's or feed line go and save the instruction take pic of it make a diagram of it some were someone said it goes to the acc in fuse box did i read wrong. and hope someone will be up to sharing that information with me thanks if you will help with this . there are some that don't have the money or like to do it the old way #1spudman eat lot's of potatoes
Old 07-03-2012, 05:53 PM
EOD Guy's Avatar
As a matter of fact, I did spec out my new fuse block before I did the finial install.
The PDF file is the fuse box, frt view (fuse side) and the rear view engine connector side. I also attached my wire diagram for my 67 camaro...... I have alot of extra things ie..... pwr windows, locks, Dakota Digital gage cluster etc.... but between the two you might be able to complete your project
Old 07-04-2012, 10:05 AM
thanks but i can't git you attached files to open and real like to see the pic can you you tell me what cirit does the incoming power that feeds the fuse panel go to, is it going to the acc fuse ??? and thanks you given me lite at the end of to tunnel #1spudman
Old 07-04-2012, 10:43 AM
thank you EOD guy i got it open and it's is just what im looking for you are the MAN sound's like you was in the services my THANKS to you and to all that served #1spudman
Old 07-04-2012, 06:05 PM
EOD Guy's Avatar
Hope it helps you out..... it took a long time to draw out. I have had too many projects that I didn't have a wire dia for and troubleshooting was a mess...... so now I draw one anytime I add something etc.....
Stupidest instruction in the world! Dave57210 Off-Topic 3 08-02-2010 08:27 AM
Looking for an instruction book Wayhot444 Introduce Yourself 3 01-20-2006 09:00 PM
I need some quality instruction younguyw/oldcrap Transmission - Rearend 7 05-15-2005 07:31 AM
instruction video richardson110 Engine 1 03-14-2004 09:33 PM
parts instruction manuals awsum34 Hotrodders' Lounge 3 11-29-2002 06:27 AM
