Wire's from driver side seat belt area - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2010, 07:57 PM
(83-Chevy Silverado)I was trying to wire my amp today and discovered 2 wires coming from my driver side seat belt. I haven't been able to see exactly where they start or end...1 is black with a white stripe and goes to the fuse block, the other has an orange and white wire running side by side, which goes toward the glove box..I can't find them on the diagram I have..anyone know what these wires go to?
Old 05-30-2010, 10:13 PM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
Seat Belt Light. You May Not Notice It If You Don't Buckle Up Cause It Will Go Out After 1.5 Min.
Old 05-30-2010, 11:46 PM
oh ok, well my warning light doesn't work, so I know where to start troubleshooting...thx
Old 05-31-2010, 06:03 PM
The orange and white wires are usually for the courtesy lamps. It probably runs up into a junction in the cab corner behind the driver. At that junction it branches out to the bed light and switch.
Bruce
Old 05-31-2010, 09:13 PM
Thx for the replies, I confirmed the white black wire goes to a connector by the seat belt and the orange and white wires are for the dome light.
Old 06-11-2010, 01:01 AM
fast68's Avatar
likes chevy trucks & boobies
orange hot all times
ground is the white wire, but it is only grounded when a door switch is extended(door opened)or when thr headlight switch knob is rotated all the way til it clicks,
then it grounds this white wire
to make the dome light light up
seat belt wires almost always black or close to it
they are probably ground circuit wires.
not positive on that
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
65 mustang seat belt? tom penicaro Interior 2 05-30-2009 12:49 PM
Seat belt upgrade? MT71c-10 Interior 4 10-14-2008 06:21 AM
Seat Belt Suggestions steve392 Interior 5 08-03-2008 04:10 PM
Driver side window th2hh General Rodding Tech 1 03-26-2004 07:03 AM
