Originally Posted by FRANKBULLITT
its the insulation on the actual wires it also went through the plastic conduit. anyway im on my 3-4th coat of liquid electrical tape and that seems to be working good ,a couple more coats and ill tape everything with 3m 333 and rebundle it all in a new plastic conduit and hope for the best.
Back in the late 70's and into the early 80's, Ford used a 'white' grease, it looked like lithium grease to me, inside of the main wire harness connections. This 'grease' would wick down the wire, and shrink the insulation exposing up to an 1" and a 1/2 of bare wire.
I offered this as a cheaper alternative, to the cut/shrink tube/splice repair. I have never seen, or heard of any problems using this. It does set up pretty hard over time, but it does not get brittle and break off. You have to cut it off with a knife.
