Wirewheeling rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2006, 06:31 PM
Everything is HAMMER!
Wirewheeling rust
Ok guys, the underside of my car has some surface rust, the back quarter also has minor surface rust. I've used the wire wheel to take rust off thicker metal but no body panels or floor boards, I need to know why no-one does this does it warp the panels or take off to much metal?
Old 01-16-2006, 06:50 PM
I wire wheel small spots occasionally that I don't want to bother sandblasting. The reason I don't do it often is it takes longer and harder to do a good job getting all rust out of the pits. I suppose it may heat up the panel some, but think you probably would have to really try to build up enough heat to warp a panel with one.
Old 01-16-2006, 07:16 PM
I have to tell you, a wire wheel is the last thing I would use simply because they SUCK. After you use a 3M "Clean-n-strip" wheel or a "Surface conditioning disc" you will toss the wire wheels in the trash where they belong.
I have not used a wire wheel in YEARS. Heck, they "polish" the rusty metal more than clean it.
Old 01-17-2006, 05:56 AM
I still keep a selection of fine, medium, braided, and epoxy coated wire wheels in the shop. Although the kleen n strip wheels work well and much better than wire wheels in most situations wire wheels still have their place. Using Randy Ferguson's method of rust removal with Naval Jelly I've found a fine bristle wire wheel to work great in between jelly applications. Sometimes I use them for polishing, and sometimes I use the old encapsulated type mule skinners in tight areas where the kleen and strip won't work. They all have their place. I'd never consider wire wheeling a complete underside-have it sandblasted and be done. Bob
Old 01-17-2006, 10:17 PM
Thanks for the replies, this is as bad as it gets(I know you southern guys are thinking, holy crap thats bad) but thats better(much) than it usually gets up here in the rust belt. I guess I could have it sandblasted and get it done with but I don't know any shops from around here that do it, I could do it but i'd have to do it in my shop and thats not gonna happen too much engine stuff , not real sure how safe jackstands would be outsid but i certainly don't want to get under that thing sitting on jackstands on all four corners(any creative solutions are very well appreciated). I've heard bad stuff about blasting body panels too, would that blackbeauty stuff work well without warping it to crap.I've got more to say but i'm tired and can't think of it.
ID:	9315   Click image for larger version
ID:	9316   Click image for larger version
Old 01-20-2006, 02:29 PM
I agree that wire wheels have their place but I believe that they just "polish" the rust in many cases. If you have your doubts, pick at the wire wheeled area with a scraper or screw driver and see what happens.
jim
Old 01-20-2006, 05:27 PM
There has to be someplace near you that could sandblast it for you reasonably. Being the area you are in with the frequency of rust, which I know too well about also, being in a neighboring state, I would there would have to be at least a few shops. I really don't like sandblasting, it gets everywhere, and sticks to you in the summer time when you are hot and sweaty if you are not covered head to toe. Almost would be worth taking it to be done if you find a place to do it at the right price. I only have a siphon blaster at this time, and it takes for ever to do anything with one of them, but I never really noticed any warpage from it. A siphon feed puts out a lot more sand, but probably have to be more careful and not really hammer body panels and keep it moving. The black sand didn't work to well with my siphon, fine silica is what I have been using, cheap and effective, but its not the safest for your lungs. A pressure feed maybe the black sand works better. A pressure feed blaster is on my list for must haves this spring. I think if you are contemplating doing the underneath at all yourself, I would try to line up or buy a rotisserie so you are not laying on your back with crud falling on top of you.
Phosphoric Acid + Prevention of flash/surface rust unstable Body - Exterior 13 11-15-2015 07:09 AM
RUST..What are the acceptable permanent ways to get rid of it? Rocket1 Body - Exterior 213 10-30-2011 06:23 AM
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
04 mustang rust oldred Body - Exterior 3 07-19-2005 07:15 AM
