Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wiring
Thread: wiring
Old 10-03-2012, 07:08 AM
JOHNSHENOUDA JOHNSHENOUDA is offline
Wiring
PATM, you are amazing. I taped the ground wire on the steering wheel and amazingly when I connected the battery no horn and no starter. Could it be that little stick-en ground wire was causing all that mayhem? I felt like I was welding with my battery cable. I did notice that the headlights and the hazard lights were working. Also i keyed up the car and all of the gauges fired up. I guess that is a real good sign. However I found that my turn signals are not working. Still have not checked the fuse, it is possible I fried something trying to hook it up. My concern is that once I install the horn will my starter kick on everytime I honk?
