Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2010, 04:38 PM
Wiring
Good day,
I am restoring my Camaro and it's at the wiring stage.Before I start I
would like to get some ideas about hiding as much wire as I can.Any ideas?
Thanks JB
Old 10-28-2010, 05:17 PM
302 Z28's Avatar
You can hid just about all the wiring under the hood by running it inside the frame.
Vince
Old 10-28-2010, 05:21 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Make sure you have a schematic diagram on hand before you begin.
Use grommets anywhere you go thru sheetmetal.
To extend wires, cut and solder and then use heat shrink over the connections.
Old 10-28-2010, 10:59 PM
Originally Posted by johns79camaro
Good day,
Thanks JB
Heat Shrink
Loom (braided is my preference - they also now make a 'split braided' that is really nice)
zip ties where necessary
Use the frame to your advantage
Hope This Helps!
Old 10-29-2010, 08:05 AM
Wiring
Thanks for all the info.I will try to find some split braid and route it
through the inner fender panels as they are open on both sides.
JB
Electrical Wiring kristkustoms General Rodding Tech 16 12-27-2010 11:00 AM
Trinary switch wiring ? fatdog Electrical 8 01-25-2010 06:57 PM
home aluminium wiring - danger pigjamelectric Off-Topic 9 07-30-2009 09:58 PM
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
