Wiring 1984 Chevy Caprice Classic - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 03:38 PM
kringold's Avatar
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
I just rebuilt the 305 that's in it and I have about 9 wires left where I don't know where they go. I do have the shop manual and it has helped alot. But now I've found the wires in the car and on the diagram for the EST. What the heck is an EST and where is it?
Old 05-30-2005, 05:21 PM
docvette's Avatar
Wiki Edits: 12
Est
Doc here,
Electronic Spark timing..
Should plug into the distributer (on the engine bay side) in lieu of a vacuum advance...
Depending on your year / model & engine setup, may or may not be used, and may have been added as a factory option.
I think the crossover year (80/81) had the option, and after was the EST, whether used or not...but don't hold me to that..
Anyway, If you have Mechanically adjustable timing, and advance control,and is non TBI, EFI...(carbed) then you don't need this plug.. just tape it back, however if you have one of the above, you do...
We are Talking GM right? Need to know more about the setup to accurately advise you further..(year / make/ model/ orig eng or swap/harness swap/etc)
Doc
Old 05-30-2005, 05:48 PM
kringold's Avatar
1986 Chevy Caprice Classic original 305 and original wiring harness with an HEI distributor. It has a Rochester Quadrjet model E4ME feeedback carb.
wiring schematic - '80s Caprice Engine compartment gtofloyd Electrical 3 12-08-2003 10:58 AM
ignition/coil wiring 72 chevy p/u icegnome Electrical 2 12-21-2002 05:59 AM
wiring diagram (1992 350 c.i. chevy pickup) dunegoon Electrical 1 12-15-2002 03:56 PM
engine wiring diagram (92 350 c.i. chevy pickup) dunegoon Engine 2 12-15-2002 01:46 PM
77 chevy malibu classic trans. problems crustytheclown87 Transmission - Rearend 1 08-13-2002 05:56 AM
