wiring for 1992 S-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2004, 04:40 PM
need diagram for 1992 S-10. "Kids" put stereo in and now her taillights fan etc will not work. Fuses blow, wires melt, I've got a real mess to fix. Any Ideas out there?
Old 11-28-2004, 06:00 PM
The library usually has some good resources for info. Here I have been able to find all kinds of wiring diagrams. You need to ask not just look for yourself. I have found some of it is not check outable and is then behind the counter. They will usually make a copy for you. I am an electrician by trade and I have found the best way to trouble shoot a ground in a car electrical system is to get a 12 volt light bulb, solder wires to it and put it in place of the fuse. If you have a ground it will light up brightly. When you clear the ground it will either go dim or out. Keeps from blowing fuses. That can get real expansive.
Gary
Old 11-29-2004, 05:49 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
http://www.autozone.com/servlet/UiBr...n=viewHomePage
go here & sign in & look around & you'll find what ya need....joe
Old 12-02-2004, 04:45 AM
willowbilly3's Avatar
Last journal entry: Body mods
Wiring diagrams and component locaters are invaluable when doing electrical work but they won't always lead you to the part that the monkeys with 8 miles of red wire and a roll of black tape screwed up. Why not start by having the "kids" undo what they did, it might make your task easier.
