Wiring 2 Relays in series??
Can I wire 2 relays in series to a 12volt ignition wire??
Relays are made double throw double pole. Why use two if you can get one that does the work of two.
Check it out Last edited by DENCOUCH; 06-07-2008 at 03:35 PM. |
You can hook up 2 or more relays using the same switch wired to positive or ground. Your power out of the relay just goes to what ever you want to turn on with the same switch.
This is common on dual electric fans along with a transmission cooler fan using 3 relays from the same switch. Most of the off road race vehicles have multiple relays wired together for the lights, and multiple relays for the electric fans for the engine, trans, oil, etc., coolers. This is my favorite link on wiring relays. http://www.6066gmcguy.org/BoschRelay.htm |
if it's a GM, then there is an unfused ignition assessory spade terminal you can plug in to, you could just use that, or trigger the relays with it
I'm not trying to be mean but I'v been in a bad mood as of late.....all I was referring to was some of his past posts.....
Alternator not lining up, PICS! Alternator Bracket Mounting SBC Help and this one for sure Pulleys Don't Line Up Sbc, Pics, Help!! |
sexypizzaman Registered User Join Date: Mar 2006 Location: Vancouver Posts: 186 Wiki Edits: 0 re: Alternator Bracket Mounting SBC Help -------------------------------------------------------------------------------- Thanks a lot for the help guys now i can see how it goes!! And for you Holder350, if you don't want to help then don't say anything at all. Forums are for people WHO ARE LEARNING, for asking people with experience these questions and HOPEFULLY receiving some help. If you are just going to bash a thread why even post?? Why waste your time typing if all you have to say is garbage?? Don't know if anyone else agrees with me but I didn't think forums were for that..... |
Do you mean in a series or parallel? I can't see any reason to use two in a series but if you want to double the current carrying capacity, for instance use two 30 AMP to carry 50 AMPs or so, you can do that by using two parallel and in fact some electric fans have this set-up, I think Painless wiring has one like that.
thanks for that oldred.....I actualy needed this a few weeks ago and had to go with a expensive 100 amp unit for a alt shutdown relay....but about 4 little 30 amps would have worked just as well.....
*kicks self in but*
| Is it possible to stroke a 400 more than it already is? | stonedchihuahua | Hotrodding Basics | 18 | 11-10-2012 08:27 AM |
| wiring up a efan with relays? | Boostedpimp | Electrical | 19 | 05-19-2008 03:14 PM |
| EZ wiring project | zipfactor | Electrical | 3 | 05-21-2006 03:55 PM |
| Wiring An Electric Fan Using TWO Relays | horvath | Electrical | 29 | 05-13-2004 11:57 AM |
