Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wiring 2 universal wiper motors together
Old 12-15-2011, 11:07 AM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
you're still better off with a DPST switch, but if you insist on using the diodes...
the 1N400x diode is only rated for 1 amp, you will need to do a little research on diodes to figure out which one to use with a motor.
this is a radio shack 3 amp diode for $1.79
