I have 2 universal wiper motors that I have wired together They are wired as follows:
The negative terminal (-) goes to ground.
The positive terminal (+) goes to a fused power source.
The switched terminal (S) goes to one side of a toggle switch and to ground from the other terminal on the toggle switch.
This is not a "Mighty Wiper" brand as their wiring is not as above.
My problem is that when I start the wipers they work and if after a few seconds I shut them down they will shut down. However, if I leave them on for more than say, 20 seconds, and then shut them down, they won't. They keep on running. Sometimes (rarely) they will shut down, but more often than not they won't. I've been told that a diode is needed as there may be some feed back. There are no relays in the system and I don't want to rewire the whole system so that each wiper has it's own source. Each wiper comes from a common feed and each wiper comes from a common ground. Question.....what type and size of diode do I need and where does it go?
your running 2 motors with one switch, i assume that the switch grounds the motor and when you switch it off the internal park switch grounds it until the motor parks. if the motors are getting out of sync after running for a minute or 2, when you turn the switch off, each motor is grounding the other motor thru the park switch.
what i mean by getting out of sync is one motor is running a little slower than the other one. they both start out going left, right, left; but after while you might see them going opposite of each other or slightly out of whack with each other.
try running each motor separately to see if both motors park right after 2 minutes. if they both work fine then either use: a DPST (double pole, single throw) switch to separate the grounds. or if the switch matches your other interior switches, use 2 relays to disconnect the grounds.
a 1N4001/L diode would work if you had feedback thru a relay. a relay take a small load to energize. a 1N4001/L diode will not take a lot of power, such as a motor load. you could buy a big diode but it would be cheaper to try either suggestion above.
No this is a new installation. I thank you for the info. Being so close to Christmas I probably won't be able to do what you suggest until after the holidays. I know what you mean by being out of sync., but I'm wondering if there is any way to run them into a common sync? Reason for asking is that these are mounted on a '32 Tudor and the windshield is not that big, so there might be an overlap of the blades which could cause a problem.
i drive my truck everywhere in all weather (no salt), i use rain-ex and have never turned my wipers on. i have the arms and blades mounted in case i run up on a truck spitting mud, but have never used them. we ran all day in the rain from indy to muskegon on the HRPT. never turned them on.
I believe in Rain-X too! It's wonderful stuff and I would probably run without the wipers in place, but the challenge is to see this thing through. Had some time today and disconnected one wiper. Works and parks! Did the same for the other one. Works and parks! Ran them both together and saw that they were definately out of phase, but they did stop when shut off. BUT, one parked and the other didn't. Now if I used a diode, where would I place it and would this cause both wipers to park? Really appreciate the feedback.
you're still better off with a DPST switch, but if you insist on using the diodes...
the 1N400x diode is only rated for 1 amp, you will need to do a little research on diodes to figure out which one to use with a motor.
I can't thank you guys enough. The switch that I'm using is a universal SPST lighted one thats fits into a rectangular hole. Now the search is for a DPST that will fit into this hole (may have to widen the hole somewhat, which is okay).
I'm working on a '32 Ford Tudor and yes I realize that the arms will never synchronize. The switch(SPST) that I'm using is rated for 15 Amps. They're single speed and they both share the same ground. My only concern is to get the wipers moving so that I can safety the car to the satisfaction of the inspector. After that Rain-x will be my wiper mode.
27........Done a many '32 stock & street rods. Yes, you do have the bulkhead opening on the right side...for export right hand steering.
Why does inspector require dual wipers if it did not come with dual wipers ? Titled as a '32 ? What State ?
Would a variable intermittent switch set near full speed synchronize the wipers.? wired in the ground side , turn off the wipers after a few wipes for a second, then let them both start back up at the same time.
You still have not answered questions about DMV requirements:
What State ?
What tags are you applying for ? Daily driver ? Street Rod ? Antique/classic?
Did DMV inspector show you regulation on paper ?
I have wired over 200 Street Rods since I started my business in 1957. Built many rods.
You have seen my cars in magazines & TV, winners circle.
Tried DPST 15 amp switch back in the '80s on Tiwan motors from Vintique Inc.
Looks like motors have improved.
Glad it worked.
Keep kroozen
Jim
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
