wiring????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2012, 02:58 PM
oldmanchopper
Last journal entry: Update
wiring?????
I have a 58 chevy truck with a small block,kwik wire 22 circuit wiring harness,pertronix dist., chevy mini starter, when I turn key on the starter runs. I have everything (I think) wired like it supposed to be from all the directions in booklet from kwik wire. There is something wrong but can't figure it out. Can someone help?
Old 01-31-2012, 03:04 PM
delawarebill's Avatar
wiring
do u have the start sol wire.... wired in the run position ???? sounds like it... needs to go in the start position...
Old 01-31-2012, 03:14 PM
oldmanchopper
since I don't have but 1 terminal on starter which one should the one from coil go to? battery(big) or st (small)?
Old 01-31-2012, 03:52 PM
68NovaSS's Avatar
Wiki Edits: 9
Moving to the Electrical forum
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 01-31-2012, 04:11 PM
EOD Guy's Avatar
Chevy color code.... should have a purple wire from the key switch to the "S" terminal on the starter, The other terminal on the older starter was for the old point/coil type dizzy.... the wire from the pos side of the dizzy went to the "I" terminal on the starter to provide full 12v to the coil while starting. After it starts the "I" went dead and the coil received 9ish volts from the run position on the key switch via a resistance wire... ballast resistor etc..... so you wouldn't burn up the coil. Modern HEI dizzy run on 12v ....so no need for the resistor or the "I" terminal.
Old 02-08-2012, 09:44 PM
You could try to simplify things with pcb connectors
http://www.rustechpcb.com/
Old 02-09-2012, 07:41 AM
T-bucket23's Avatar
Wiki Edits: 26
If the car had a starter with wires on both the I and S terminals you cant simply put them both on the same terminal, (s terminal) if you do the starter will run as soon as you turn the key on.
Chet
Old 02-09-2012, 04:17 PM
EOD Guy's Avatar
To answer your question in post 3......... IS the dizzy an HEI or points?...... if HEI disconnect the wire from the coil to the "I" terminal and discard. If the dizzy is a points type..... go get a new starter with the "S" and "I" terminals and connect the wire from the coil to the "I" terminal and the purple wire from the switch to the "S" terminal. It might work with the points type dizzy by leaving the wire off but you won't get the full 12volts when cranking etc..... which might lead to hard starting etc...
EZ wiring - back up light wiring copdwg Electrical 3 06-07-2008 06:42 PM
'58 F-100 wiring 6 pack Electrical 9 09-17-2003 06:16 AM
58' F-100 wiring 6 pack Electrical 0 08-30-2003 06:51 AM
s10 wiring krausman Electrical 3 04-08-2003 12:13 PM
Hei wiring rehjr0219 Electrical 4 02-05-2003 01:56 PM
